Re: My 3π adventure [message #95710 is a reply to message #95260] Fri, 24 June 2022 19:18 Go to previous messageGo to previous message
T-nuts installation is going smoothly!
/forum/index.php?t=getfile&id=3083&private=0
After some tests I found that these small t-nut prongs, at least in mine, need pilot holes in order to go into the wood without bending. I used 1.5mm drill bit and just 2mm depth, all they need is just a little help. I am driving them down with an Allen screw and a washer. A Philips screw won't do, there's not enough torque. I am finishing this with some 5-min epoxy.
I am a bit troubled about crossover placement. I get that the best place would be the bottom, under a fiberglass flap. However I don't like this since I am afraid it's going to mess up the insulation near the port and I will have to mess with fiberglass in order to reach it. Would it be really bad if I mount it at the uninsulated side, vertically with 6 wood screws? Also Wayne if you do have a picture of a bottom-mounted 3pi crossover with insulation installed please share it here.
Next Topic: 7 Pi plans
Current Time: Mon Apr 29 10:30:32 CDT 2024
