Re: 4pi build with stands finally realized [message #94426 is a reply to message #94425] Tue, 14 September 2021 06:03 Go to previous messageGo to previous message
Final results.
/forum/index.php?t=getfile&id=2840&private=0
Woofers installed. I have one question regarding the woofers. These are 2226H which I bought used, and I believe they are original and imported from USA. But the cone and dustcap has a brown colour, and all the others I see on pictures are grey/charcoal. So are they reconed with non o.e.m. cones, or is it an early production? I hope some of you guys can chime in on this.
/forum/index.php?t=getfile&id=2841&private=0
Happy with the speakon solution on the bottom. Makes the rear a ot cleaner.
/forum/index.php?t=getfile&id=2842&private=0
/forum/index.php?t=getfile&id=2843&private=0
Had to make some grilles too. Wanted a more factory finish, and I thought my wife would find them less intrusive too. This is our main living room so I wanted them to look as nice as possible. The grille is made as small as possible. The frame is not going inside the woofer gasket and allows for 8mm excursion before it touches the fabric. They are now hanging on the woofer gasket, but I have ordered small neodym magnets. These will be glued to the gille frame and sticks to the bolt heads for the woofer.
/forum/index.php?t=getfile&id=2844&private=0
/forum/index.php?t=getfile&id=2845&private=0
/forum/index.php?t=getfile&id=2846&private=0
/forum/index.php?t=getfile&id=2847&private=0
Current Time: Wed May 15 03:24:41 CDT 2024
