Home » Audio » Home Theater » Projector heats up and turns off
Projector heats up and turns off [message #90834] Thu, 05 September 2019 14:02 Go to previous message
I haven't had the projector that long, so I'm surprised it's having problems. I do use it a lot though. I've made sure there is room around the projector for airflow and I've tried the usual fixes such as cleaning out the dust with a can of air. Maybe I need a dedicated cooling fan, but I'd like to avoid that if possible because they're so loud. Any other fixes I should try?
Previous Topic: Smart TV minus the adware
Next Topic: Used home theater
Current Time: Thu Nov 19 05:10:08 CST 2026
