gofar99 Messages: 1905 Registered: May 2010 Location: Southern Arizona
Hi, Hybrids can excel in some areas. Where there is the need for a lot of gain and low noise solid state devices do very well. However, how they sound may not be to everyone's liking. If you want a warmer sound, often caused by the presence of even harmonics then tubes will probably sound better to you. A hybrid with a high gain front end feeding tube output circuitry can be very nice. It depends on the design and execution. If all the gear has a cathode follower output (like many of the budget hybrids seem to do) then it is not likely to make any difference.
