Home » Sponsored » Pi Speakers » Amp for 4pi speakers (Integrated stereo amp without dsp or AVR with audyssey)
Re: Amp for 4pi speakers [message #89290 is a reply to message #89288] Wed, 28 November 2018 15:17 Go to previous messageGo to previous message
Wayne Parham wrote on Tue, 27 November 2018 16:47
But when I've run subwoofers as "helper woofers" - in the configuration I call "flanking subs" - I generally don't run them that high. They are localizable if the rolloff if made too high. I generally use low-pass between 90-120Hz second-order, which provides quite a bit of output in the 100Hz to 200Hz region because rolloff is so gradual.
You could try 150Hz second-order, which would definitely provide output up to 200Hz and beyond. But it might start to sound unnatural when run that high.
Thank you for the answer, Wayne. I've read the post through and I realised that this was exactly what I tried to do a few years ago in our previous house! Smile
This was my setup with (temporary) flanking subs:
/forum/index.php?t=getfile&id=2273&private=0
This was the measurement with one flanking sub:
/forum/index.php?t=getfile&id=2274&private=0
With the second flanking sub:
/forum/index.php?t=getfile&id=2275&private=0
Bass response improved, but the 100hz-300hz was still too pronounced to me.
/forum/index.php?t=getfile&id=2276&private=0
/forum/index.php?t=getfile&id=2277&private=0
... which made me sell the subs. Sad
I might buy new ones (but maybe smaller ones that blend aesthetically more in our living room, really "helper" woofers that won't go lower that the JBL woofers).
But I guess that those helper woofers will particularly fill the notches but won't lower the complete 100hz-300hz frequency range that is little bit too pronounced because of our room acoustics?
Previous Topic: 4pi build and questions
Next Topic: 7Pi Build 2014
Current Time: Sat May 04 15:46:53 CDT 2024
