Home » Sponsored » Pi Speakers » 4Pi Rough concept
Re: 4Pi Rough concept [message #88161 is a reply to message #88150] Sun, 10 June 2018 20:36 Go to previous messageGo to previous message
Starting to look like a speaker now.
index.php?t=getfile&id=2137&private=0
Had to remove some of inside trim as it was interfering with the port tube.
index.php?t=getfile&id=2138&private=0
Finished inside of box
index.php?t=getfile&id=2139&private=0
Got to finally listen to just the woofer a bit. Hooked it up as right channel and kept existing small bookshelf speaker as left. Didn't have all ports on cabinet sealed and no insulation or bracing. Sounding much more like a speaker. Was amazed by how much the box was resonating at only 5 watts. The back panel was just tapped in place without any screws, and it felt like rubber. I've only had small bookshelf speakers prior to this and didn't realize how powerful this speaker will be. Definitely going to brace as recommended, and then some.
Paul
Previous Topic: 7Pi Plans request
Next Topic: 3pi crossover
Current Time: Mon May 13 19:02:33 CDT 2024
