Home » Audio » Source » Ping Hurdy-Gurdy
Ping Hurdy-Gurdy [message #12442] Wed, 10 August 2005 13:24 Go to previous message
I am unable to link to the thesis defining the differences between S-Shaped and Straight line Tonearms. I can give you the very short story and if it is interesting I can follow up with the math and theory.
The inertia of the effective mass at the stylus tip is the least value with a straight arm, given by the equation detailing the moment of inertia of the pickup arm and counterbalance about the axis of rotation,( the arm pivot), divided by the sqaure of the effective arm length. In other words a straight arm will have less inertia present at the stylus tip and therefor should provide a less wearing less distorted output.
If you do a search of tonearm geometry there is several sites that do an indepth analysis of this behaviour.
Try Baerwald; there is a good pdf. file dictating some of his work on the tangency of pivoted arms.
Previous Topic: Audio CD-R Compatibility
Next Topic: HELP with my Acoustic Research XA!
Current Time: Sun Oct 25 23:25:01 CDT 2026
