Home » Sponsored » Pi Speakers » 3 Pi plans
Re: 3 Pi plans [message #89912 is a reply to message #89870] Mon, 11 March 2019 17:15 Go to previous messageGo to previous message
Mabob is currently offline  Mabob
Thanks for all the information on flanking subs and the corner horns. After much consideration and I think that I will upgrade my 3pi.s to 6pi cornerhorns. I think that way I'll make the most of my limited space.
The back wall is about 3m wide and if I build flanking subs I'll get the speakers too close to my listening position. It'll also be a good challenge to build the mid horns, I really like the look of them!
One thing that bothered me about building flanking subs was finding the right amplification with proper filters. My HT amp has no pre outs, only sub out, which is a mono signal I think. And the plate amp I have has a much steeper lowpass filter than the one you recommend.
So at the moment 6pi feels like the way to go. Additional multisubs might be used if I feel it's necessary. If I understand it right, there is nothing wrong with horn subs as long as not being used as flanking subs?
Built some speaker stands to get them down to the right level. This was a big update that didn't cost much Rolling Eyes should have done this ages ago!
Well, I'm eager to start a new build, so can I have the 6pi plans please!
/forum/index.php?t=getfile&id=2344&private=0
Previous Topic: 2 Pi completed
Next Topic: Pi
Current Time: Fri May 17 08:10:41 CDT 2024
