Home » Audio » Movies & Music » Do you think that music should fit the scenes? Or is it just personal preference?
Do you think that music should fit the scenes? Or is it just personal preference? [message #85312] Fri, 02 June 2017 22:18 Go to previous message
PlayerNM is currently offline  PlayerNM
I think you can either make or break a movie based on the music that is used. For instance, would Psyco be as good without the music for the show scene? Don't you need a build in intensity when horror shows get to the scary parts? Let me know your thoughts.
Previous Topic: Prison Break season 5
Next Topic: Songs you associate with shows.
Current Time: Sun Nov 22 23:16:15 CST 2026
