Home » Sponsored » Pi Speakers » Seven Pi Loudspeaker Component Questions
Seven Pi Loudspeaker Component Questions [message #81699] Tue, 01 December 2015 16:47 Go to previous message
George Swanson is currently offline  George Swanson
Hey everyone (but especially Wayne),
I bought a set of mid horns for the 7pi corner horns a while back and have been searching for a pair of JBL 2012H midranges since then with no luck. I've decided that the best is the enemy of the done so I'm going to buy the Eminence midrange and woofer.
I have a couple of questions about components. Wayne, I see that you sell the Jantzen capacitors. I've heard good things about the Superior Z Caps, would you be able to get those and include them in the kit for an upcharge? Also a question on inductors - is there any sonic improvement for a larger gauge inductor or is it simply a matter of power handling? I'm going to be using a pair of push pull 6B4G power amplifiers so I'm not going to be needing the speakers to be arc welder amp compatible.
Also, I've managed to lose the plans you originally sent. Would you mind sending me another set? Thanks!
Previous Topic: 6pi Mains, 3pi Center
Next Topic: 4 Pi Plans Request ; )
Current Time: Wed Nov 04 03:30:26 CST 2026
