Home » Sponsored » Pi Speakers » 6pi Mains, 3pi Center
6pi Mains, 3pi Center [message #81670] Fri, 20 November 2015 18:41 Go to previous message
I have been studying the 6pi plans, and noted the tweeter/midrange are located significantly higher than the normal "tweeter near ear height" rule.
With curiosity I searched, and found a message that indicated this is intentional, something to do with wall boundary effect(s) bringing the sound down to normal ear level height at the listening position.
Interestingly, I also found mrwhippy's 7pi build thread, where he indicated he thought the speakers sound seemed to come from above a little, as if one was sitting near the front row of a raised stage (to me indicating the mid/horn might be a little high after all).
I am also curious as to what height a 3pi center channel should be placed if used with 6pi mains, I assume the more normal horn near ear level (or aimed there) applies.
Appreciate any comments/explanations regarding the 6pi mid/horn height, and 3pi horn height in an LCR build.
Previous Topic: 7-pi conversion
Next Topic: Seven Pi Loudspeaker Component Questions
Current Time: Fri Nov 13 07:18:27 CST 2026
