Re: 4 Pi Build Progress [message #81523 is a reply to message #81518] Thu, 06 August 2015 16:50 Go to previous messageGo to previous message
Sanding sanding sanding....so the first primer I put on needed a lot of sanding, I have the 3 pi subwoofers done! They are finished with Rustolem Hammered Black spray paint. It's a pretty nice look for the subs.
One 4pi is fully primed ready for more sanding before I start the stone gray enamel. the other 2 have the first primer put on and need a lot more sanding. The primer is basically the same color as the stone gray I'll be painting them.
index.php?t=getfile&id=1788&private=0
I'll be out of town for work all of this weekend and and most of next week. My goal is to have all the paint on minus a the clear coat before I go. another 4 hours of sanding with some painting in between and I might be there.
Next Topic: Implementation
Current Time: Mon May 06 21:24:17 CDT 2024
