Home » Sponsored » Pi Speakers » Will 7Pi work in my room?
Will 7Pi work in my room? [message #80793] Sat, 08 November 2014 06:21 Go to previous message
despearce is currently offline  despearce
My main listening room is 17'3" x 11'4" and 8'6" high. I currently have my speakers on the long wall around 10' apart and sit on a bed to listen which is equidistant between the speakers on the opposite wall.
I could have the 7Pi firing either direction across or down and in the corners. If I have the speakers firing down the room the bed will be between the speakers.
Which would be best and where would the optimum seating position be?
I am open to suggestions if other speakers are more suitable, I drive my current (94db 3 way) speakers with a 30w valve amp.
Previous Topic: What to use to power/EQ a 4.2 theater?
Next Topic: Guidance when looking for used 2226Hs?
Current Time: Mon Oct 26 10:40:14 CDT 2026
