Home » Sponsored » Pi Speakers » 2 PI - maximum volume to avoid Helmholtz standing waves
2 PI - maximum volume to avoid Helmholtz standing waves [message #80181] Sat, 12 July 2014 21:20 Go to previous message
CRISTIAN M is currently offline  CRISTIAN M
Hi Wayne,
I'm preparing myself to build a pair of 2PI to be used primarily as stereo speakers (not for home theater or anything like that), so they need to be as full range as possible.
BUT...Due to physical constraints in my living room I cannot use the tower version of the 2PI. I cannot even use the "standard" bookshelf version because they won't fit either (I need to put them at boths sides of a big sofa and in between 2 small tables, so the remaining space is 25.6 / 2 = 12.8 inches per speaker at most)
Anyway....Somewhere on an old topic you mentioned "You can make a box between about 1.5 ft3 and 5.5 ft3 tuned to 40Hz and make the Alpha 10 happy". The bookshelf version for 2PI is 1.5ft3, while the tower one is (roughly) 4.5ft3, so I wonder - gradually going up from the minimum recommended volume - what's the maximum enclosure volume for the 2PI before you start suffering from severe standing waves?
In your opinion:
1. would something like 12"(W) x 17"(D) x 27"(H)(rougly 2.7 ft3) work in a decent way? Or maybe 12" x 16" x 25"?
2. would port positioning for that enclosure be as crucial as with the tower 2PI's?
3. would that volume require bracing?
Thanks!
PS. I read literally 42 pages of posts (almost back to 2008) trying to find some answers, so please be patient with me Very Happy
Previous Topic: 2Pi Help...
Next Topic: Four Pi build plans, please
Current Time: Sun Nov 22 21:45:31 CST 2026
