Home » Sponsored » Pi Speakers » Coax in horn
Coax in horn [message #76917] Sun, 02 June 2013 20:19 Go to previous message
Zene Gillette is currently offline  Zene Gillette
Hi ... thanks to Wayne I'm making a 12" version of his mid horn.
I will be using my P.audio 12" CX38 coax. I won't need (or want)the compression driver, so will need to do something with the gaping 4" horn. Options seem to be; stuff to kill resonances, cover with dome either attached to cone or just cover horn mouth. Problem there is it's more permanent if attached to cone. Last, make a phase plug.
I'm not expecting this horn to get to more than 800hz if that helps selection.
Before I do something stupid I thought I'd better run it by you guys.
Thanks, Zene
Previous Topic: Damping H290C horn
Next Topic: 4pi's on the way!
Current Time: Sun Nov 29 04:57:32 CST 2026
