Home » Audio » Speaker » Reusing Speaker boxes!!!
icon5.gif  Reusing Speaker boxes!!! [message #73303] Mon, 16 July 2012 15:09 Go to previous message
GFOviedo is currently offline  GFOviedo
I currently own a HT-S9100THX 7.1 HTIB system. It sounds okay for what it is, but my awesome 3 year old son decided to poke the center channel, and right front speaker. He also spilled some soda (Coke to be specific) to the right front speaker.
I ended up replacing the center channel with a Klipch Synergy C1. I re-used one of the speakers that was still good from the center channel, and put it in the right front speaker, but the center channel speaker was damaged a little bit, and it sounds awful whenever it sounds a big loud or with a lot of base.
Therefore, I was wondering if there is a possibility to use different speakers with the same box. I went to several car audio places, Best Buy, and Lee's Stereo / Home Theater system, but they didn't have anything to help me.
The part # for the speaker is SKF-960. I found about this place via AVS Forum. Thanks for any suggestion. I will get some dimensions when I get home and take some pictures of the boxes. Thanks.
If you cannot understand my silence, you will not understand my words!!!
Previous Topic: New Project - The DR912a Line Arrays
Next Topic: iFish and iDog
Current Time: Sun Oct 18 11:36:52 CDT 2026
