Home » Sponsored » Pi Speakers » Clamp Rack
Clamp Rack [message #72818] Fri, 25 May 2012 16:42 Go to previous message
This was so easy. Why did I wait so long to get the clamps off the floor and out of the corners?
First, I needed a crosscut sled because the miter gauge that came with my cheap-ass tablesaw sucks. Second, I thought I needed a dado set for the saw. Second, Part B, w/o a dado set I'd have to make numerous passes with the standard blade to cut the kerfs.
Well, retirement's main virtue is time and it's evil counterpart vice, empty time. I had time to fill so I made the sled this A.M. and found a website that showed drilling a hole at the back of the kerf which means only 2 saw passes per. Why didn't I think of that?
Ecco! Clamps on the wall before lunch!
index.php?t=getfile&id=785&private=0
Previous Topic: Wood used in 4PI construction
Next Topic: would these work with the 3pi design?
Current Time: Tue Oct 20 08:01:07 CDT 2026
