Home » Audio » Group Build » IR Remote Control
Re: IR Remote Control [message #74524 is a reply to message #74512] |
Tue, 20 November 2012 23:27 |
Messages: 18680 Registered: January 2001
These prototypes were sort of a step back in time for me. I used to always make prototypes like this, and that all-red wiring was my signature build style. I've done prototypes that were 50 times more complex, no kidding. One processor/controller I did filled a board twice that size. So this is nothing, four chips and that's it. Just nothing. Kinda wanted to do it that way, just for sentimental sake.
These days, I'd definitely do a small PCB run for protos. Back in the day, it was too expensive to do that. I'd only go to fiberglass once I was doing a run of several hundred at least. But these days, they'll practically give you a short run on the hopes you'll do a long run.
I still have relationships with some of those shops, because I still get boards. I buy lots of crossover boards, for example. I sometimes get the pretty silkscreened boards with plate-through holes, solder mask and silkscreening. Other times, a simple single-sided board without a mask or silkscreen is fine. The crossover boards are the latter.
So but anyway, my IR-remote protos are a labor of love, probably a last hoorah for me on the point-to-point perfboard build style. Just had to do it, one last time.
And, yeah, like Shane said, Uriah had boards made. I did the processor chips for others to develop boards and systems for. I didn't want to go in the amplifier business, 'cause then I'd sort of be in competition with the guys I made the chips for. So this is just a firmware deal, and I'll provide the chips, allowing others to provide the rest.
IR Remote Control
By: gofar99 on Thu, 21 June 2012 13:31
By: gofar99 on Fri, 31 August 2012 15:33
By: gofar99 on Fri, 31 August 2012 21:25
By: Shane on Tue, 16 October 2012 10:58
By: Shane on Tue, 16 October 2012 13:49
By: Shane on Fri, 19 October 2012 22:19
By: Shane on Tue, 30 October 2012 22:00
By: gofar99 on Tue, 20 November 2012 19:41
By: Shane on Tue, 20 November 2012 20:42
By: gofar99 on Tue, 20 November 2012 21:06
By: Shane on Tue, 20 November 2012 22:26
By: Shane on Sun, 06 January 2013 21:48
By: gofar99 on Mon, 07 January 2013 21:51
By: Shane on Mon, 07 January 2013 22:23
By: gofar99 on Tue, 08 January 2013 10:40
Current Time: Mon Apr 29 06:12:03 CDT 2024
