Home » Sponsored » Pi Speakers » H290C Horn/Waveguide (Upgrade for the obsolete Eminence H290)
Re: H290C Horn/Waveguide [message #73809 is a reply to message #73777] |
Thu, 13 September 2012 09:37 |
Messages: 18680 Registered: January 2001
Glad your new waveguides sound good to you.
Interestingly, your impressions are the same as mine. I've measured the H290C and I've listened to it, and my listening impression seems subjectively more of an improvement than the measurements show. The H290C waveguide just really sounds natural to me.
Other people have said the same thing too. There's been enough time now for people to install their new waveguides and listen to them. The feedback I'm getting is very positive. I'm hearing a lot of similar opinions, using phrases like "smoother", "less distorted", "more natural" and "cleaner sounding".
The measurements are good, but the old H290 measured surprisingly good too, better than most waveguides out there. So by response measurements, you might not expect much difference between the Eminence H290 and the new Pi H290C, maybe not even enough to hear. While the H290C's oblate spheroidal / elliptic cylinder flare profile is the best shape, in my opinion, other profiles can be nearly as good provided they are close enough. But the H290C is better sounding, probably because it stays true to the OS/EC flare profile. Comparison of measurements don't really show this improvement as much as one might expect.
Of course, the measurements I'm talking about are just response and polar measurements, and they will only show very strong internal reflections in the form of response spikes. Smaller reflections won't show up in a response chart, and it may be that this is the difference. It would make sense, given the OSEC waveguide/horn generates the least (HOM) high-order modes. So I think the difference, while subtle, is audible.
I'm also pleased to hear your comparison of the Pi H290C with the QSC waveguide. I've received emails from a few others that compared it with the JBL and SEOS waveguides as well. I'm getting unanimous feedback that the H290C sounds better. This, again, I attribute to the pure OSEC flare. Other manufacturers deviate from it for one reason or another.
The new H290C waveguide just sounds better. I thought maybe it was just a proud papa thing, but since I'm getting feedback that the H290C sounds "smoother", "less distorted", "more natural" and "cleaner sounding" than the old Eminence H290 and other waveguides, I'm starting to think it isn't just me. Many people are reporting back positive results like this.
By: santos on Tue, 27 March 2012 03:48
By: Maxjr on Thu, 29 March 2012 13:26
By: Maxjr on Thu, 17 May 2012 16:37
By: zheka on Fri, 27 July 2012 19:58
By: zheka on Sun, 29 July 2012 08:32
By: mantha3 on Tue, 31 July 2012 11:17
By: mantha3 on Tue, 31 July 2012 14:28
By: blvdre on Tue, 31 July 2012 15:35
By: Maxjr on Thu, 16 August 2012 07:42
By: Maxjr on Thu, 16 August 2012 14:11
By: gofar99 on Sat, 18 August 2012 14:35
By: Maxjr on Wed, 22 August 2012 22:48
By: rkeman on Thu, 21 March 2013 14:20
By: zheka on Tue, 23 April 2013 09:59
By: zheka on Tue, 23 April 2013 11:03
By: zheka on Tue, 23 April 2013 11:20
Re: H290C Horn/Waveguide - closest equiv. in 1.5" or 2"?
By: tubino on Thu, 17 September 2020 14:41
By: tubino on Fri, 18 September 2020 06:40
Current Time: Mon Apr 29 03:06:25 CDT 2024
