Home » Sponsored » Pi Speakers » 6 Pi Crossover Questions
6 Pi Crossover Questions [message #70762] Tue, 03 January 2012 10:13 Go to previous message
The 6 Pi crossover specifies L2 with the Eminence Delta 10A and states in a footnote that the tweeter polarity should then be reversed. Is it correct that the B&C DE250 would then be wired in normal polarity (positive to red and negative to black)? Also, is there a way to calculate an additional 2 or 3 db of attenuation to the midrange and tweeter circuits? Because the crossover will be mounted in a separate enclosure it would be easy to add DPDT switches for flat and attenuated tweeter and midrange networks. Thanks for any assistance that you may be able to provide.
Previous Topic: 6 pi plans
Next Topic: Towers
Current Time: Mon Oct 12 07:03:13 CDT 2026
