Home » Sponsored » Pi Speakers » Midrange Horn
Dimensions [message #44381 is a reply to message #44377] Tue, 13 April 2004 06:31 Go to previous messageGo to previous message
JLapaire is currently offline  JLapaire
Are the dimensions given as INSIDE? So the throat is 4.5 x 4.5 for a compression ratio of about 3:1 with the Delta 10?
A question about HF mating - would the use of H290 instead of H295 allow less padding of the Delta due to less CD pull-up required?
Discontinuity in the horn flare will probably rule out the 10CX in this application now that I think about it. If I had one I'd try it anyway though.
Once again, thanks for sharing your designs. Simple = Elegant, especially when the engineering is sound (no pun intended).
John
Previous Topic: How good is the 1Pi? Pretty good, I think.
Next Topic: I covet the 7Pi Plans...
Current Time: Sat May 11 14:46:32 CDT 2024
