Home » Audio » Thermionic Emissions » Super simple linestage.
Re: Super simple linestage. [message #9139 is a reply to message #9138] Mon, 01 August 2005 18:11 Go to previous messageGo to previous message
Thrint is currently offline  Thrint
I did not say that anybody wanted to build this unit. Or that there were no other ways to achieve the results. It is just another way of doing things.
If you're sugesting a simple voltage divider pot, the pot and buffer I just laid out ought to run circles around it.
Since I have a feeling that there is substantial prejudice against SS stuff, I thought to show a way it could be used to good effect. Always use the best design to solve the problem. Sometimes it might just be a SS one. FWIW, I don't recall anybody complaining about the performance Guenivere delivered.
regards,
Douglas
The suggested PS of 60-0-60 would yeild ~50 volts at the L-C filters.
Previous Topic: Chicago Audiofest Website
Next Topic: SET amps that will only rock Septeguenarians
Current Time: Wed May 15 17:04:07 CDT 2024
