Re: Pete's Home Theater Build [message #76979 is a reply to message #76978] Fri, 07 June 2013 13:35 Go to previous messageGo to previous message
Sounds like a great plan. I think that's what I would do too.
Are you still planning to run constant directivity cornerhorns? Or are you going back to your original plan of using four π mains? The cornerhorns would be perfect for that room, but one advantage of the four π's is you can put 'em just about anywhere. The subs where you've shown will reduce self-interference from nearest boundaries if you blend them with the mains. So that's a good setup too.
Previous Topic: H290C in Altec coaxial
Next Topic: Pi 3 questions
Current Time: Sat Apr 27 12:41:34 CDT 2024
