Home » Audio » Group Build » Need help with crossover design
Need help with crossover design [message #67035] Wed, 13 April 2011 12:09 Go to previous message
endrek is currently offline  endrek
Hi,
i want to build this speaker design:
Speakerplans.com
but i want to change the HF compression driver + horn .
Which parameters should i look?? Dispersion? Same sensitivity?? Any advice please?? Wich parameters should be good with the two woofers from the speaker??
http://www.paudiothailand.com/pdf/products/PC-5038.pdf
http://www.paudio.ru/downloads/SD740N.pdf
http://www.selenium.com.br/site/asse..._pdfManual.pdf
THX for all
Previous Topic: Switchbox -- 6 in, 1 out
Next Topic: Two new valve based projects
Current Time: Sat Nov 07 10:43:03 CST 2026
