Home » Sponsored » Pi Speakers » looking at 6 Pi's (6Pi Question)
icon12.gif  looking at 6 Pi's [message #62392] Sat, 24 April 2010 10:50 Go to previous message
andrewbeee is currently offline  andrewbeee
Hi Wayne,
I am looking for your advice. My room is ~ 16' X 36' with the speakers on the short wall. I have been into single drivers for many years but its time to move on and try something new. I listen ~ 12' away from the speakers. I was considering a pair of 6 Pi's.
I would go with the 7's but in my mind 15''s are overkill.
In the case of the 6 PI, would you consider the AE TD12S a considerable upgrade to the Delta 12LF?
If yes, then what about the crossover? Would I be better off doing better caps and inductors with the AE TD12S only or would the Delta benefit in a like manner to the more expensive components?
I also am interested in the 4 Pi's but that midrange horn on the 6 & 7 PI's keeps calling me. I would think a dedicated mid horn would flesh out the mids more clearly and you must have had a reason for it.
What do you suggest?
I do not listen very loudly, I would guess peaks in the high 90's once in a Blue moon.
In any case, would you please send me the plans for the 6PI and 4Pi along with your suggestions?
Thanks
Andrew
Previous Topic: One, Two or Two Tower
Next Topic: Port Tube Needed for 2Pi Towers?
Current Time: Tue May 14 13:48:00 CDT 2024
