Home » Sponsored » Pi Speakers » 8 Pi horn and woofer?
8 Pi horn and woofer? [message #62278] Sun, 04 April 2010 11:45 Go to previous message
Hi Wayne,
Does the 8 Pi use the same midhorn as used in the 7 Pi corner speaker? If not, could you outline some of the differences?
Also, is the 10" Eminence woofer used in the 8 Pi the same as used in the 7 Pi corner speaker?
Thanks
Norris
Previous Topic: Just scored a pair of 3pi speakers!
Next Topic: Just received a set of 2 Pi's ...
Current Time: Sun Nov 29 08:15:40 CST 2026
