Home » Audio » Speaker » Any decernable results from round over at mouth of horns and cabinet edges?
Any decernable results from round over at mouth of horns and cabinet edges? [message #59293] Sat, 23 May 2009 10:40 Go to previous message
Has anyone here done enough experimentation with horns that use a large round over at the mouth edge like Jean-Michel Le Cléac'h
uses to determine it's effect, pro's con's?
If so, what are the differences of a Le Cléac'h horn compared to a design similar to something JBL would use in their studio monitors where the horn mouth sharply terminates and are set against a flat baffle wider than the horn?
Have you added a rounded over extension in the fashion of the Le Cléac'h type to the mouth of a horn such as the Emminence H-290?
If so, what were your conclusions?
Also, has anyone found positive enough effects making it worth implimenting rounding over, or chamfering speaker cabinet edges?
If positive effects were found by rounding over, or chamfering cabinet edges. What size of edge rounded / chamfering was needed to realize these effects, 1/2", 3/4" or larger?
Thanks
NW
Previous Topic: high eff. 3way.
Next Topic: Open Baffle Visaton B200 & Eminence Delta
Current Time: Sat Oct 17 05:05:02 CDT 2026
