Home » Sponsored » Pi Speakers » Two for one
Two for one [message #53220] Tue, 17 February 2009 00:24 Go to previous message
Zene Gillette is currently offline  Zene Gillette
Wayne ... in positioning my PI 7 wanabee horns as you suggest; i.e. aimed at a point just ahead of the seated position, I discovered that with the rotating horn lazysusan system for the UB and mids I find that the correct distance is probably somewhere between minimum at the equilateral seated position and several feet behind that.
Should I maintain the same focal point distance at each test position? All I remember you saying was just ahead but did not specify an actual distance or speaker offset angle. To do several angles at each seated position would put the tests in the +hundreds. I would like at least one constant in the test and ASSumed that to be the focal point.
Two ... I don't seem to be able to change speakers (only add) in CARA. I know I should have saved bare room (complicated), but did not. CARA is slow to answer. Thanks again, Zene
Previous Topic: LAB-12 CROSSOVER ?
Next Topic: Wayne, can I get the plans for the pi 7 18"?
Current Time: Wed Oct 28 23:30:08 CDT 2026
