Home » Sponsored » Pi Speakers » minor mid-horn mods
minor mid-horn mods [message #52356] Sun, 20 July 2008 14:30 Go to previous message
Wayne,
I'm close to making up a pair of mid horns, but have a small problem. I need to finished width to be 24", including the outer
box they'll go in. I was reviewing the dimentions from your post 14408 and if I cut both sides and top/bottom to be 4.5" at the
small end, and butt joint them, the horn entrance won't be 4.5" square because of material thickness. In any case, if I need to
narrow the width slightly (~1.5"-2"), should the sides be angled
in to maintain horn length, or just shorten the whole thing a little?
Thx, Chris
Previous Topic: Thanks, Wayne!
Next Topic: Lower tweeter placement in 7Pi
Current Time: Sat Nov 07 06:29:40 CST 2026
