Home » Sponsored » Pi Speakers » High Efficiency 15" Woofer Suggestions For 9 Cu Ft Ported Box ??
High Efficiency 15" Woofer Suggestions For 9 Cu Ft Ported Box ?? [message #51162] Fri, 08 June 2007 14:06 Go to previous message
Ka7niq is currently offline  Ka7niq
I built some sealed, corner mounted subwoofer cabinets using a super long throw 15" TC Sounds LMS 4000 driver.
They look like the Klipschorn botoms.
I was thinking of going to a higher efficiency driver in a ported arrangement.
Since these are corner mounted, an honest 30 hz response would do the trick.
Any favorite woofers that would work well in this box ?
The driver is down firing, and there is room on the bottom baffle to not only mount the driver, but place a port as well.
Previous Topic: anyone tried B&C compression drivers?
Next Topic: 12 pi Subwoofers - How warm is too warm for plates
Current Time: Fri Oct 23 09:44:22 CDT 2026
