Home » Sponsored » Pi Speakers » Eminence APT-50 super tweeter
Eminence APT-50 super tweeter [message #50695] Tue, 13 February 2007 19:39 Go to previous message
Ken.R is currently offline  Ken.R
Hi Wayne, awhile back you told me how to add the JBL 077 slot tweeters to my Seven 18's that you designed for me. These are your Sevens that are on Martinellis site. The drivers used are the 2245h, 2123h, 2426h. I added the 077's with the cap and the resister like you told me to with great results. At this time I use the JBL LE85 in place of the 2426h with good results also. I just purchased a pair of custum mini smith wood horns that are hooked up with the Eminence APT-50 super tweeters. Could you please tell me what capaciter and resister I need to use to run this from my Le85 tweeters.
APT-50 SUPER TWEETER SPECS
8 OHM
Power rating 45 WRMS @ 3.5 KHZ
18 DB/OCTIVE 85 WRMS @5.0 KHZ
USABLE FREQ RANGE 3.5 HZ-20 KHZ
RECOMEND CROSS 3.5 KHZ
SENSITIVITY (1 W @ 1 M MOUNTED TO TEST HORN 105 db
Thanks KEN
Previous Topic: Two unrelated questions for Wayne
Next Topic: Pi One Towers - Finished!
Current Time: Mon Nov 23 02:46:08 CST 2026
