Home » Audio » Speaker » Screw Loose (Screws for a JBL 2226 woofer)
Screw Loose [message #98116] Thu, 12 December 2024 05:48 Go to previous message
I'm looking for the screws that will fit a JBL 2226 woofer. Bought a big pack of 10-32 machine screws that have the correct threads but the head is too big to fit into the speaker frame.
Looked online. Seems the JBL uses something called a Fillister head screw. Please let me know if that isn't correct.
You can buy them in massive quantities that run $60 or $800 dollars or you can buy used ones on Ebay for $4 or $5 each.
Anyone know of a source for a small quantity of new ones?
Many thanks,
Barry
Previous Topic: Can speakers still compete?
Next Topic: Do you feel excited having tall DIY speakers than commercially made ones?
Current Time: Sun Oct 11 22:53:17 CDT 2026
