Home » Sponsored » Pi Speakers » 3Pi plans and questions (3Pi plans and questions)
3Pi plans and questions [message #97152] Thu, 02 November 2023 15:36 Go to previous message
scwheat is currently offline  scwheat
Can you also send me the 3Pi plans? I would like to use the B&C DE250 if that makes a difference. I'd like to build 3 for LCR.
A few questions as well.
What would your recommendation for LFE crossing over to a 15-inch sub via the receiver? IE 80 (for a starting point)
I'd also like to build two for surrounds (if the cabinet was not so deep). If I did the math and made it 10 inches deep but taller would that be ok. Assuming the internal volume was the same.
I see I will need to get the horn from you. Do you also sell completed crossovers?
Thanks in advance.
Previous Topic: New to pi speakers - four π plans
Next Topic: 4 Pi Build in San Luis Obispo - Flush Mounting and Bracing
Current Time: Sun May 10 03:33:14 CDT 2026
