Home » Sponsored » Pi Speakers » SPL rating affected by horn?
SPL rating affected by horn? [message #94541] Sat, 02 October 2021 09:51 Go to previous message
Hi all,
Do different horns change the combined SPL of a compression driver horn combo?
More specifically, does a narrower horn, say a 60 degree horizontal horn versus a 90 degree horizontal horn change the 1 watt at 1 meter SPL? Same compression driver.
Since the narrower horn is concentrating the output energy, would it have a higher SPL measurement at 1 watt? If so, how much higher on average?
Thanks,
Tom
Previous Topic: 4pi Speakers - Are My Tweeters Wired Incorrectly?
Next Topic: 4pi build with stands finally realized
Current Time: Mon Apr 29 09:13:29 CDT 2024
