Home » Audio » Group Build » 300B project, part 3 - PS model
300B project, part 3 - PS model [message #31275] Mon, 22 August 2005 12:16 Go to previous message
I simply use the parts I have and PSU Designer II (Duncan Amplification). I have 370+370V/0,3A transformer, and L-input PS is not possible, I need B+ about 410-430V. Then, I choose C-input with small first cap, two independent PS on the same HV winding, each with its own tube rectifier (5V4G) and CLCLCLC configuration... Let`s see:
-I1 current tap (4mA) is actually resistor load, about 100k
-I2 current tap is 300B (80mA)
-I3 current tap is driver (18mA)
Actual parts I used:
C1 = two 4,7µF/630V Wima MKP4 in parallel
C2 = 200µF/500V Mundorf M-Lytic HV electrolytic
C3 & C4 = 47µF/600V M-Tubecap polypropylene
L1 = 10H/250mA/98 Ohms, AE-Europe
L2 = 10H/150mA/140 Ohms, Schmidbauer
L3 = 10H/~50mA/285 Ohms, salvaged/old stock
Current ratings of the chokes is overdimensioned. All parts (especially caps) must be for 500V working voltage minimum.
On PSUD diagram we can see 30ms "segment", 1s after "turn on".
-The green line is ripple voltage, Vc1~80Vpp, from 400-480V. The DC voltage is Vc1 = Vc1p - Vripple/2 = 480 - 80/2 = 440V.
-Vc2 is yellow line, after first Pi-filter (L1/C2).
Vc2 = Vc1-RwL1*IL1 = 440 - 98*(0,018+0,08+0,004) = 430V. We have little ripple, Pi filter lower it S1=Vrc1/Vrc2 = (2Pi*f)^2*L*C =
= (2*3,14159*100)^2*10*200*10^-6 = 789,57 times, and Vrc2 =
= Vrc1/S 0 80/789,57 = 0,1Vpp.
-Vc3 is blue line, our B+ for output stage, after L2/C3 filter.
Vc3 = Vc2 - RwL2*IL2 = 430-140(0,08+0,018) = 416,5V. Our second Pi-filter lowers the ripple voltage 185,5 times and we theoretically have just 0,54 mVpp ripple here.
-Vc4 is a white line, our B1+ for the driver, after L3/C4 filter.
Vc4 = Vc3 - RwL3*IL3 = 416,5 - 285*0,08 = 411V. Third Pi-filter lowers the ripple voltage to just 0,003mVpp theoretically.
-Red "spikes" are ripple current waveforms on C1. Although we "draw" about 158mArms from our transformer, C-input means sharp peaks of 465mAp! That`s why we prefer L-input, if we can...
-Actual measured voltages on breadbord shows only a few volts difference in comparison with simulation.
Previous Topic: The DRD update
Next Topic: so let's speak of mods to the Aikido circuit of John's
Current Time: Sun May 12 05:27:58 CDT 2024
