Home » Audio » Group Build » Guinevere layout tips?
Guinevere layout tips? [message #30487] Sat, 12 February 2005 10:09 Go to previous message
I'm starting to put things in place (now I know why they call it stuffing) are there any other tips to on placing components. Earlier it was mentioned that the DM2540s should be at right angles, which I've done. The Tx's and choke arealso set at right angles to one another.
I will be using Belden 8450 (2 conductor shielded w/drain) as much as possible for signal and power path. Heaters will be wired with silver-plated copper wire with Teflon insulation. I will mimick Bottlehead's SEX kit as much as possible for the appropriate wiring choice.
What about grounding the Tx and choke frames to earth? Also, the tube sockets I'm using have a center pen for ground. Should this go to earth as well?
Any and all suggestions are more than welcome......Colin
Previous Topic: Ground scheme
Next Topic: Guinevere Schematic links
Current Time: Sun Apr 28 14:28:45 CDT 2024
