Home » Audio » Craftsmen » Solder Joint Design
Solder Joint Design [message #29067] Mon, 26 April 2004 20:10 Go to previous message
brian is currently offline  brian
Hello all,
If You were to solder two parts leads together what sort of join would You make? Does it matter? Would an audio component sound the same if the wires of it's solder joints were twisted together before soldering in one instance, and wrapped around each other in the manner of a blood knot in a second experiment? [as in this illustration http://www.jacksonholeflyfishing.com/library/blood_knot.htm
but of course without passing the ends through that center opening. I only refer to the wrapping instead of the usual method of bringing two wires parallel to each other then twisting them.]
Can excess wraps create an inductive coil?
Do You prefer some third method?
Previous Topic: How long before I can lick my cabinet?
Next Topic: Get artistic
Current Time: Tue May 14 00:49:11 CDT 2024
