Home » Audio » Silicon Valley » TEAC A-L700P Review
TEAC A-L700P Review [message #10297] Tue, 22 February 2005 11:46 Go to previous message
Martin is currently offline  Martin
I have been looking to upgrade my amp and preamp for almost a year. I really want two amps so that I can also play with bi-amping my Lowthers with a 15" HE woofer and an active crossover. I know what I want, the wife has given her blessing, it is expensive but I can afford it, but I am too cheap. This is going to be expensive, but she said go ahead, and I spent the past year half heartedly looking for less expensive alternatives. I know if I find and buy a less expensive alternative, I will wish I had bought what I really wanted and kick myself later. So with that background, I'll get on to my real message.
I am definitely a little bit slow at catching on to the latest audio trends. About a month ago I started becoming interested in the Sonic Impact amp. Reading the reviews and forum discussions from the past six months there seemed to be something going on with this product that was truly special in some people's eyes (really ears). Reading TNT Audio and 6 Moons reviews spurred me forward, I wanted one (or maybe two).
What a deal, $29 at Target or Parts Express. As I said above, basically I am cheap and screw myself constantly by buying less then I really want or need. I am working hard to break this habit and $29 is less than a tank of gas for the Explorer. So $29 dollars for a giant killer was just too hard to resist. With my credit card in hand I hit the Internet to buy a Sonic Impact amp. SOLD OUT EVERYWHERE (except the manufacturer who wanted $39, NO WAY)! But as I am searching, my cheap side is starting to total the add ons required to really make this thing work in my system. Add a AC/DC plug-in or some form of battery power, add some adaptors to make my speaker cables fit the amp's cheap binding posts, add a RCA to mini head phone jack converter to connect my preamp, and the cost was rising to a still very affordable $60 to $70. But they were SOLD OUT EVERYWHERE!
It looked like the Sonic Impact amp was going to be a challenge. At the same time I started reading about the Teac A-L700P three channel amp for $99. It has binding posts, RCA connection, and plugs into the wall. It would drop right into my system in place of my aging Adcom 200 watt amp. So I took the plunge and bought one from Amazon.
The Teac amp arrived a couple of weeks ago and I pulled the Adcom out of my cabinet and onto the floor and set the Teac on top (this thing is less than half the size of the Adcom). A couple of quick connections and I was listening to music. One interesting side note, looking though the cooling holes I could see two small PC type boards and not much else. The case is really fairly decent with average mid-fi type connection hardware, no complaints about the construction for the $99 delivered cost. I have been listening on and off for a couple of weeks and been fairly happy, my only suspicion was that the bass output was weaker then the Adcom. On the plus side, the midrange and high end appeared to be brighter, crisper, and more detailed/revealing.
Yesterday, Audrey (the wife) and the two girls went out shopping leaving Jeffrey (13 year old son) and I home with a bunch of chores to get done. By the time her car hit the bottom of the driveway the chores were forgotten and we were headed for the amps. Time for some serious comparison listening to my Lowther ML TL speakers at volume levels not normally achieved in the evening without complaints. We listened to a bunch of different recordings including jazz, classical, male and female vocals, and even some of his stuff (junk! really bad!) with both the Adcom and the Teac. Switching cables and firing back up took about a minute so we would listen to the same music selection with both amps very quickly.
Bottom line, Jeffrey said he did not hear much of a difference. I thought that the Adcom had a bit better low bass response and in general sounded a little darker. The Teac had a very revealing brighter midrange and high end. The differences were small. I know that the Adcom/Lowther set-up produces very decent sound from the comments made by several recent visitors. I know they would have been honest in pointing out significant flaws in my system and I don't believe they were just being polite. I also recognize that my Adcom amp/preamp are the weak links, the reason I am looking for an upgrade. Neither the Adcom nor the Teac are perfect and I am still going to buy a more expensive high end SS amp and preamp, but no longer two expensive amps as I had planned so I have saved myself some very decent bucks. The $99 the Teac is really amazing. I have ordered a second Teac from Amazon, this time at $95 (even cheaper!) and will use the two Teac amps to experiment with bi-amping in the near future. The Teac amp is so small and light that I can think of many uses for the pair as I continue to build and experiment with more speaker systems.
If you are looking to try a Sonic Impact type of set-up, I can easily recommend the Teac A-L700P three channel amp as a slightly more expensive yet more conventional amp that will drop right into an established system. The only reservation might be that the Teac amp will probably work best with high efficiency speakers that have an impedance curve with a minimum value greater than 6 ohms.
My two cents,
Martin
Previous Topic: Sonic Impact Technologies Class T Amp
Next Topic: Sharp SD-EX111
Current Time: Wed May 08 16:15:34 CDT 2024
