Home » Sponsored » Pi Speakers » 811b's and PSD2002 in 4pi Theatre
811b's and PSD2002 in 4pi Theatre [message #50220] Sat, 04 November 2006 22:19 Go to next message
As you know Wayne, I have purchased some Altec 811b horns for the 4pi Theatres I am building. In searching through the Pi Forum archives I found where you had posted this:
"The PSD2002 sounds excellent on the Altec 811 with the same crossover used in the Theater four π speaker. You can really consider the whole kit to be a good second source to Altec components for the Model 19 loudspeaker, but swap the polarity of the HF driver."
Why the polarity swap?
Re: 811b's and PSD2002 in 4pi Theatre [message #50221 is a reply to message #50220] Sat, 04 November 2006 23:34 Go to previous messageGo to next message
Cuppa Joe is currently offline  Cuppa Joe
Hey, Paul! How's life & business?
Re: 811b's and PSD2002 in 4pi Theatre [message #50223 is a reply to message #50220] Sun, 05 November 2006 10:38 Go to previous messageGo to next message
The 811 is a longer horn and it moves the driver into a position where there is destructive interference in the crossover range. By swapping polarity, you can maintain acceptable summing.
Re: 811b's and PSD2002 in 4pi Theatre [message #50224 is a reply to message #50223] Sun, 05 November 2006 11:32 Go to previous messageGo to next message
Ahh, that's what I thought, wanted to make sure.
Thanks, Wayne!
Re: 811b's and PSD2002 in 4pi Theatre [message #50225 is a reply to message #50221] Sun, 05 November 2006 11:33 Go to previous message
Staying busy! As usual.
Previous Topic: Crossover Values and Impedance 2nd & 3rd order
Next Topic: DI Matching
Current Time: Sat Oct 31 12:59:52 CDT 2026
