Home » Sponsored » Pi Speakers » sub test
sub test [message #50163] Sun, 15 October 2006 15:55 Go to next message
j.luis cruz . is currently offline  j.luis cruz .
Hy Wayne . Could the 12Pi handle the 5 hz tone present in the rocket lift off scene of the incredibles movie
Re: sub test [message #50164 is a reply to message #50163] Sun, 15 October 2006 23:25 Go to previous messageGo to next message
At 5Hz, the 12π is nothing but a small sealed-box loudspeaker system with a bunch of wood around it. The 12π is designed to be used between 30Hz and 100Hz, and while I think it's the most powerful and highest quality speaker within that band, I don't recommend it for use outside that band. Below 30Hz, I'd suggest a direct radiator rather than a horn.
Re: sub test *thanks Wayne* [message #50166 is a reply to message #50164] Mon, 16 October 2006 07:55 Go to previous message
thanks for your answer Wayne.But
Previous Topic: midhorn
Next Topic: Stage Seven Pi-18
Current Time: Mon Nov 02 14:20:09 CST 2026
