Home » Sponsored » Pi Speakers » pi x over
pi x over [message #50086] Tue, 26 September 2006 10:12 Go to next message
j.luis cruz . is currently offline  j.luis cruz .
Hy Wayne . Could work a Pi x-over in a non Pi Box . I said this because I modeled the Delta 15 LF and in a 19 fc box give a amaizing. thanks
Re: pi x over [message #50087 is a reply to message #50086] Tue, 26 September 2006 10:17 Go to previous messageGo to next message
The crossover will work in similar cabinet arangements, yes. What's important is the each driver's range is similar so that there are no holes in response, and also that the placement and orientation of drivers in relation to each otrher are similar so that summing is right.
Re: pi x over [message #50091 is a reply to message #50087] Tue, 26 September 2006 16:10 Go to previous message
the drivers used could be PSD 2002 and Delta 15LF and a big 8 inch PVC port . thanks for your answer .
Previous Topic: Goodmans Axiom 201
Next Topic: OT: Computer Audio
Current Time: Tue Oct 20 17:23:06 CDT 2026
