Home » Sponsored » Pi Speakers » Professional Four Questions
Professional Four Questions [message #50042] Mon, 18 September 2006 13:40 Go to next message
xcortes is currently offline  xcortes
Hi.
I'm new to this forum. I have been reading about your speakers and I would be interested in building/buying a set of Professional Fours for my Home theater. I have several questions, however:
1. How would these speakers work for Home Theater Applications? I will be using 300B SET amps for the 5.0 channels. The main left and right and the center channel will be placed at about 5 meters and the surrounds maybe at two.
2. How good or bad is their vertical dispersion?; ie, how important is to have them exactly at ear level?
3. Can I buy kits for the five channels but without the woofers and deducting them for the price? That is because I live in Mexico and I can get the JBL woofers here without needing to bring them down which would make the project prohibitive. The rest of the kit could be shipped to CA and I would bring them down, including the HF drivers.
4. Is the 2226 woofer the H (8 ohm version)?
5. In an old post Wayne recommended JBL 2242's to build matching subwoofers with these speakers. I can get here 2241s but not 2242s. A simulation with this driver and a 340 liters box tuned to 30Hz gives me an F3 of 30Hz. Would this be a good driver for building the 0.1 channel and latter maybe augmenting subs for the main left and right speakers?
6. Can I get the plans for them in advance to start working?
Thanks a lot,
xavier
Re: Professional Four Questions [message #50043 is a reply to message #50042] Mon, 18 September 2006 14:35 Go to previous messageGo to next message
The Professional Series four π loudspeaker is a very nice sounding speaker. It works well with many tube amps, having a fairly flat impedance curve and good efficiency. I'll be happy to send you the plans if you tell me your E-mail address.
The Professional Series four π uses a JBL 2226H (8 ohm) and a JBL 2426H or Eminence PSD2002-8 compression driver. The horn is a 90x40 radial design, and the design crosses over where the midwoofer matches horizontal directivity with the tweeter. Best listening area in the vertical is within the 40° pattern of the horn. Much above or below this and upper midrange and treble will suffer.
I'd be happy to sell you the kits minus the woofers, so if that will be helpful, we'll do it. You can also source the parts locally.
The 2241 is an excellent woofer. They work well in a wide range of cabinets, from 4.0ft3 to 16.0ft3 tuned to 30Hz. for subwoofer use, I think 8.0ft3 to 16ft3 is best, and I've built plenty of them that were 10ft3 and they sounded great. So I'd definitely approve of your choice to use a 12.0ft3 box tuned to 30Hz.
Re: Professional Four Questions [message #50044 is a reply to message #50043] Mon, 18 September 2006 14:44 Go to previous messageGo to next message
sent you a message.
thanks!
You've got mail! [message #50045 is a reply to message #50044] Mon, 18 September 2006 16:46 Go to previous messageGo to next message
Port Question [message #50048 is a reply to message #50045] Wed, 20 September 2006 13:07 Go to previous messageGo to next message
What material do you recommend building the port tube of? The 3/4 " MDF I'll be building the speakers with or is it too thick?
Thanks again
xavier
Re: Port Question [message #50049 is a reply to message #50048] Wed, 20 September 2006 14:30 Go to previous messageGo to next message
That's perfect.
thanks (nt) [message #50051 is a reply to message #50049] Wed, 20 September 2006 15:33 Go to previous messageGo to next message
nt
Re: thanks (nt) [message #50054 is a reply to message #50051] Thu, 21 September 2006 10:00 Go to previous messageGo to next message
j.luis cruz . is currently offline  j.luis cruz .
Hey Xavier cuanto cuestan los bajos JBL 2241 . Yo vivo en Monterrey y aqui los encuentro muy caros podrias decirme cuanto y donde los consigues tu . gracias Luis Cruz Monterrey, Mexico ..ahh y Bienvenido al forum .
Re: thanks (nt) [message #50061 is a reply to message #50054] Thu, 21 September 2006 16:29 Go to previous message
Alrededor de 3,300 IVA incluido. Mejor precio que en los EU! Si entras a la pag de JBL Professional ahi te da los datos de Hermes Audio y ellos te mandan con distribuidores. Seguro tienen alguno en MTY.
saludos
Previous Topic: For GARLAND
Next Topic: LAB-12 as HT Subwoofer
Current Time: Tue May 19 13:34:05 CDT 2026
