Home » Sponsored » Pi Speakers » Theater 3 baffle size and driver arrangement
Crossover Information [message #49968 is a reply to message #49967] Tue, 05 September 2006 15:38 Go to previous messageGo to next message
I pad the horn on all speakers that also contain direct radiators. The difference in SPL is about 10dB, so padding is a requirement. It has the additional benefit of providing electrical damping, which is a good thing, since horns have a peculiar (peaky) impedance curve. Electrical damping smooths impedance a great deal.
Useful documents:
Re: Theater 3 baffle size and driver arrangement [message #49970 is a reply to message #49953] Tue, 05 September 2006 15:50 Go to previous message
Chris,
If you arrange the woofer and tweeter side-by-side, instead of one on top of the other, you'll have to live with poor horizontal off-axis response.
With traditional vertical stake, it assumes you're head will be at a certain height, but allows you to move side to side with little change in response. Putting the drivers side-by-side will allow you to stand-up or lie-down on the floor to listen, but limit your side to side listening position.
Previous Topic: Help Choosing the right Pi
Next Topic: Bass trapping with corner horns
Current Time: Mon May 13 20:40:05 CDT 2024
