Home » Sponsored » Pi Speakers » Alpha 10 for mihorn?
Alpha 10 for mihorn? [message #49867] Mon, 14 August 2006 06:42 Go to next message
Troy Moore is currently offline  Troy Moore
I see that the theater 7 uses a Delta 10 for the midrange, but I've seen references to the Alpha 10 used for the midrange on the forums and it is even mentioned on the plans. Is the Alpha an acceptable substitute? I've been thinking of playing around with adding a midhorn to my 4's to create a 4/7 hybrid and could borrow the Alpha's from my tower 2's.
Re: Alpha 10 for midhorn? [message #49868 is a reply to message #49867] Mon, 14 August 2006 11:00 Go to previous messageGo to next message
The Alpha 10 can be used in the midhorn. Compare the response curves of the midhorn below. One is a measurement using a Delta 10, the other using an Alpha 10. Disregard the amplitude because microphone distance and preamp gain were different. Both have average sensitivity of 106dB/W/M. Just pay attention to the overall response curves.
π Midhorn with Eminence Delta 10
π Midhorn with Eminence Alpha 10
Re: Alpha 10 for midhorn? [message #49883 is a reply to message #49868] Fri, 18 August 2006 16:48 Go to previous messageGo to next message
Wayne,
Is the dip around 1.8KHz a horn thing or do both drivers have
this without the horn?
Chris
Re: Alpha 10 for midhorn? [message #49885 is a reply to message #49883] Fri, 18 August 2006 23:51 Go to previous messageGo to next message
It's caused by path length differences in the throat. A phase plug could be used to extend top end somewhat, but it becomes an advantage when using a crossover under 2kHz because it serves to increase rolloff.
Re: Alpha 10 for midhorn? [message #49886 is a reply to message #49885] Sat, 19 August 2006 09:51 Go to previous messageGo to next message
Wayne,
Just to clear up a few things...
The throat in this case is just the baffle board (3/4" deep
by ~4" round or square)?
The phase plug would be just right in front of the driver's cone
to equalize the distances to the throat?
The unequal distances are causing destructive interference?
Sort of audio parallax errors?
Thx, Chris
Re: Alpha 10 for midhorn? [message #49887 is a reply to message #49886] Sat, 19 August 2006 10:14 Go to previous message
That's exactly right. It's like a reverse parallax, in that the listener receives sound from many points across the area of the throat. The distances and wavelengths involved cause destructive interference around 1.8kHz. This is a welcome rolloff though, since the horn was designed to be used to 1.6kHz.
Also right that the throat is a 4" square hole cut in the baffle board.
Previous Topic: xover
Next Topic: Professional Four Pi Plans
Current Time: Wed Oct 14 05:24:52 CDT 2026
