Home » Sponsored » Pi Speakers » Compensation circuit for 16-Ohm JBL 2426/2370
Compensation circuit for 16-Ohm JBL 2426/2370 [message #49361] Mon, 24 April 2006 08:34 Go to next message
ccvogel is currently offline  ccvogel
I decided to bi-amp and use a series cap on my 2426/2370 rather than using an active crossover. What values of cap and resistor should I use to compensate for the falling CD HF response if my tweeter is 16-Ohm?
Re: Compensation circuit for 16-Ohm JBL 2426/2370 [message #49365 is a reply to message #49361] Mon, 24 April 2006 18:24 Go to previous messageGo to next message
I think you'll find the information you need in the post below:
Wayne, thanks very much! [nt] [message #49366 is a reply to message #49365] Mon, 24 April 2006 20:09 Go to previous messageGo to next message
[nt]
Re: Compensation circuit for 16-Ohm JBL 2426/2370 [message #49368 is a reply to message #49365] Tue, 25 April 2006 07:11 Go to previous messageGo to next message
Wayne, I've been meaning to ask you this for a while. Why do you graph freq in linear instead of log scale?
Re: Compensation circuit for 16-Ohm JBL 2426/2370 [message #49369 is a reply to message #49368] Tue, 25 April 2006 11:15 Go to previous message
The log scale in Spice is just more dificult to view. The frequencies of interest are shifted and too close together in log scale.
Previous Topic: 10" horn loading
Next Topic: Need some speaker advice Wayne (and others)
Current Time: Mon Nov 02 11:03:04 CST 2026
