Home » Sponsored » Pi Speakers » Ohmite RESISTORS Non-inductive
Ohmite RESISTORS Non-inductive [message #49273] Thu, 06 April 2006 17:23 Go to next message
dB is currently offline  dB
Hi Wayne,
Check this from Ohmite International - Audio Gold Resistors.
They have non-inductive versions available. "Specifically designed for high-end loudspeaker and amplifier applications" as from their website. Isn't life beautiful?
They have a lot of different models including the 89 Series N (Non-Inductive 50W) and the HSN (Non-Inductive 100/250W).
The Audio Golds are 3 to 50W.
You have to check your area representatives for orders.
Did you find the Wima Caps MKP4 of any use? Do they sell them in small quantities?
Best Regards
Re: Ohmite RESISTORS Non-inductive [message #49279 is a reply to message #49273] Thu, 06 April 2006 22:23 Go to previous messageGo to next message
Those are good parts from a reliable, well-established company. Thanks for mentioning them, that's a good link.
Re: Ohmite RESISTORS Non-inductive [message #49285 is a reply to message #49273] Fri, 07 April 2006 11:55 Go to previous messageGo to next message
I was unaware of this series and never would have dreamed they offered such high wattages in non-inductives. Great info!
Thanks for lookin' out,
Thomas
Re: Ohmite RESISTORS Non-inductive [message #49295 is a reply to message #49285] Sun, 09 April 2006 18:06 Go to previous messageGo to next message
Hi tofo,
Just make shure you order on Non Inductive versions.
As an example the HS Series (Aluminium Housed) from Ohmite has the HSN being "N" Non Inductive. They say it "complements Ohmite's Military grade 89 Series as a lower cost (commercial) alternative". This series goes to 250 Watts - HSN250.
Sometimes they use the N in the middle of the part number as in XXX N XXXXX.
As for another brand from TYCO HS Series they use the N in the beginning as for NHS - Low Inductance. You have them from 10W to 300 Watts.
Also ARCOL (England)-- you can buy from www.elfa.se -- brand uses the same NHS-XXXXXX ordering system.
The prices go in between 6/7 € each (for 50W) and 12/13 € (100W) either you by in the shop or from the mail (I just asked the price in the shop).
I just add a link to a nice picture that could very well be a power resistor L-Pad mounted on a heatsink (for Wayne -- I know he doesn't want any more heat inside his speakers).
(http://passives.tycoelectronics.com/images/source/Heatsinkassemblies.jpg)
Thanks dB (nt) [message #49305 is a reply to message #49295] Tue, 11 April 2006 19:54 Go to previous message
Previous Topic: System seven
Next Topic: 4 pi stage plans?
Current Time: Fri Nov 06 03:59:41 CST 2026
