Home » Sponsored » Pi Speakers » Upgrades for the Pi7 crossover
Upgrades for the Pi7 crossover [message #49206] Tue, 28 March 2006 13:29 Go to next message
Kim Schultz is currently offline  Kim Schultz
Hi Wayne.
I want to upgrade my Pi7 crossover that started out with some cheap components.
I have looked at Jantzen copperfoil inductors.
14 Gauge 0.62mH 0.19ohm, or should I use the 0.56mH instead.
14 Gauge 1.00mH 0.24ohm
Do you think they will have a low enough resistance, or should I go with the 12 Gauge versions.
What about the 5mH inductor for the bass, what specs. should I look for there ?
I thought about the Janzten caps too, they are not that expensive, but I have no idea how they sound.
Re: Upgrades for the Pi7 crossover [message #49207 is a reply to message #49206] Tue, 28 March 2006 13:59 Go to previous messageGo to next message
I use those Jantzen coils too, and like them a lot. The ones you've spec'ed are just fine. As for the large coil, I suggest an Erse Super Q.
Re: Upgrades for the Pi7 crossover [message #49208 is a reply to message #49207] Tue, 28 March 2006 14:06 Go to previous messageGo to next message
Should I go for the .56 or .62 mH ?
The .56 mH might give a too high crossover point right ?
Re: Upgrades for the Pi7 crossover [message #49209 is a reply to message #49208] Tue, 28 March 2006 15:20 Go to previous message
Go with the 0.62mH, but either will work just fine. The difference is actually pretty tiny.
Previous Topic: Wayne, impedance compensation calculation?
Next Topic: Seven pi-18 photos?
Current Time: Mon Oct 19 22:44:45 CDT 2026
