Home » Sponsored » Pi Speakers » Superlux ECM-999 or Behringer ECM-8000 for Measurement
Superlux ECM-999 or Behringer ECM-8000 for Measurement [message #49010] Sat, 04 March 2006 19:45 Go to next message
bgavin is currently offline  bgavin
Does one model offer any substantial benefit over the other for measuring speaker response?
Re: Superlux ECM-999 or Behringer ECM-8000 for Measurement [message #49012 is a reply to message #49010] Sat, 04 March 2006 22:33 Go to previous messageGo to next message
Sorry, I don't know. I use measurement systems like LMS and Speaker Workship. Maybe someone else can chime in.
Re: Superlux ECM-999 or Behringer ECM-8000 for Measurement [message #49013 is a reply to message #49012] Sun, 05 March 2006 08:12 Go to previous messageGo to next message
Does LMS come with its own mic?
I have a Rane MIC1 that comes with my RA27 analyzer. Rane specs are better then either the Behringer or Superlux, even though the Rane also uses a 1/4" capsule.
Research indicates almost all these measurement mics are based on the Panasonic 1/2" omni capsule, even the pricey Earthworks models. I guess the difference is the circuit used to drive the capsule, and quality control during selection.
I was thinking about using one of my Studio Projects C4 1/2" omni condensors for measurement, but its spec sheet only goes down to 40 Hz. My Rane is probably the real solution, but I have to build a +2 power supply for it, as its power requirements are unique.
Re: Superlux ECM-999 or Behringer ECM-8000 for Measurement [message #49018 is a reply to message #49013] Sun, 05 March 2006 16:25 Go to previous message
Yes, LMS comes with a calibrated microphone. They also have an option for an improved microphone available at extra cost.
Previous Topic: the begin
Next Topic: FredT's looked so good and Shane complained, so...
Current Time: Thu Nov 05 14:36:11 CST 2026
