Home » Sponsored » Pi Speakers » Wayne: PiAlign - Strange results for Delta 12 LF
Wayne: PiAlign - Strange results for Delta 12 LF [message #48936] Mon, 20 February 2006 21:16 Go to next message
ThomasF is currently offline  ThomasF
I tried to calculate Ve = Vad/Qd with Qd = 1/Qts, and get 1.1 cft for the Delta 12LF (Theater 3), shouldn't it be around 3-4 cft? PiAlign.exe gave me the same results. I used the T/S from the Eminence website.
Also, what is the difference in sound for a PI alignment vs the traditional QB3 or C4/SC4 alignments?
thx, Tom
Eminence model changes [message #48937 is a reply to message #48936] Mon, 20 February 2006 23:23 Go to previous message
You might check out the formula in the PiAlign document. It shows what calculations are used. You might also be interested in the write-up of various alignments in the post called "Response curves of closed vs. vented systems".
About T/S specs, Eminence changes them periodically without changing model numbers. They have just recently gone through another revision for several of their speakers. Some models of π Speakers were originally designed for an earlier version Eminence driver with different specs.
This has happened several times over the years. Eminence has made many changes, a search through the archives will show several notices to that effect. If a driver change results in a non-viable system design, I modify the cabinet or drop the model altogether. But if the response isn't worsened by the driver spec change, I usually don't.
Previous Topic: Hy Wayne please.
Next Topic: pi question
Current Time: Fri Nov 06 07:43:14 CST 2026
