Home » Sponsored » Pi Speakers » Theater 4 or 7 plans?
Theater 4 or 7 plans? [message #48879] Thu, 16 February 2006 11:07 Go to next message
SteveCZ is currently offline  SteveCZ
I'm looking to build a pair of high efficiency speakers from a kit for use with a single-ended triode amp (probably a Bottlehead S.E.X.). Could I have the plans for the Theater 4 Bass Reflex speakers and the Theater 7 corner horns, so that I can figure out a total cost, and how complex they are to build?
Also, it would be great to know if in your experience they are SET-friendly. In terms of sensitivity, they look great for SET use. But, other factors (like low, or widely varying impedances) can screw things up.
You've got mail! [message #48882 is a reply to message #48879] Thu, 16 February 2006 11:26 Go to previous messageGo to next message
Re: You've got mail! [message #48885 is a reply to message #48882] Thu, 16 February 2006 11:41 Go to previous messageGo to next message
Thanks for the reply. I got an email indicating you had replied, but there was no attachment. Hotmail should allow it, but if needed I can give you another address.
Re: You've got mail! [message #48889 is a reply to message #48885] Thu, 16 February 2006 12:53 Go to previous messageGo to next message
Please give me an alternate address and I'll resend.
Re: You've got mail! [message #48890 is a reply to message #48889] Thu, 16 February 2006 14:37 Go to previous messageGo to next message
Please try:
impact_prague-sc@yahoo.com
Thanks!
Re: You've got mail! [message #48891 is a reply to message #48890] Thu, 16 February 2006 15:02 Go to previous messageGo to next message
Will do.
You probably wont regret the effort. [message #48892 is a reply to message #48879] Thu, 16 February 2006 15:20 Go to previous message
I love my Theater 4s with my Paramours. There are no discernable(by me) freq. responce anomalies. They better just about all other speakers I've heard with the Paramours, including Doc Bottlehead's own Straight 8's and many versions of fostex backhorns. Dynamic and effortless sense of power with low watt amps; esp. parafeed amps!
They are about the easiest speaker type to build (Theater 4's anyway) though they may be somewhat imposing in a small room.
G.
Previous Topic: 3-Way the other Way
Next Topic: Corner horns with no corners?
Current Time: Thu Oct 15 16:12:00 CDT 2026
